Is there a way to make my battery last longer?
I've been using the device for a while, and it seems over time that the battery life has been significantly diminished. Is there anyway to help or fix this problem?
Questa è una buona domanda?
Hey Brennan,
Great question! I think we all could use a longer battery life for all our devices! There ARE a few tricks you can try.
- Free up some RAM by closing out of apps when you're not using them
- Turn brightness down whenever possible; the backlight is a major drain of battery life
- Turn off bluetooth and wifi whenever possible
- Limit notifications
If none of these seem to do the trick, it may be time for a new battery. Head over to our battery replacement guide to get started.
Best of luck!
Brennan, did you just post and answer you own question???
@lpfaff1 Remember, I told you to watch out for questions like this. Check the OP - student
mayer, yes you did,thanks :-{(
Hey Brennan,
If none of these seem to do the trick, it may be time for a new battery. Head over to our Battery replacement guide to get started.
Best of luck!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 225
