Salta al contenuto principale
Get rid of touch and hold gesture
When I have the file explorer active and I touch and hold on the trackpad (mouse) the wheel comes up with options "home", "end", "back", and "forward". I cannot even get the thing to work. I'm just trying to turn it off.
Questa è una buona domanda?
Punteggio 1
1 Commento
I have a Noteook 9 and have this same issue. This icon randomly shows up and I have tried all the suggestions in this post and none have worked. I have also talked to Samsung Tech Dept and they have 'never heard of this problem'...which I find hard to believe. Has anyone been able to get rid of this icon on their Samsung Notebook 9? Thank you.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hopefully this will help others because this "feature" is so annoying that I was seriously thinking about exploring new laptop options and returning this otherwise wonderful Notebook 7. I had looked everywhere possible in the traditional Windows settings. This feature is a HUGE nuisance IMHO as it was causing me to constantly skip in and out of my work areas.
This solution will still allow you to utilize all of the wonderful multi-touch gestures and disable only this one setting.
To disable this:
Start up the Samsung Settings App
Go to the Input menu option
Turn off "Press & Go"
Punteggio 5
6 Commenti:
oh gosh, thank you so much for sharing this. This feature was driving me nuts and I was about to crush my laptop into pieces. I wonder what kind of an idiot thought this was cool and decided to add this feature.
da
Many thanks, the option to switch it off is so well hidden that it would be virtally impossible to find without help.
da
Thank you for saving my life.
da
Thank you so much, you've kept me from going insane!
da
I can't tell you how much I appreciated this post!! Thank you.
da
Mostra 1 altro commento
I believe this Notebook pc has Synaptics Pointing Device,
1. Type in search "Synaptics Pointing Device" and click on that entry
  • If that doesn't show go to "Control panel" and click on "Mouse Properties"
2. A Window will pop up for the Drive, In the Menu Tabs you should see "Device Options" with a -Red Logo-
  • select that option and settings for that specific driver will show, Click on "Settings" under the pointer device selection, Now you can Modify how and which gestures perform and to Disable them or not.
Screenshot posted:
Punteggio 4
3 Commenti:
Thanks for the quick response but I cannot seem to find ether of those options. =(
da
what OS are you running? The specs I looked up said windows 8.1 upgradeable to windows 10.
da
Thank you. It was hard to find, but it worked.
da
To make the wheel go away, touch the pad and don't move for about one second.
Punteggio 2
Aggiungi la tua risposta
Tony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,537
