Salta al contenuto principale
Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
89 Domande Visualizza tutte
Replacement Keys for Wireless Keyboard
I am in need of a delete key for my Apple Wireless Keyboard. My son dropped the keyboard and the delete key broke off. The clips on the back are busted and I have been unable to find a way to remount it or repair it.
Questa è una buona domanda?
Punteggio 8
5 Commenti
I need an up button
da
I n
i need a down button
da
this is for a Mac Pro Retina
da
The type will depend on which generation (year) of Retina MacBook Pro you have. You can locate exactly the right key here https://www.thebookyard.com/apple-keycap...
da
I need an "any" key. ;^)
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
If you go to an Apple store (Genius Bar), most of them will give you replacement keys for Apple keyboards for free if you ask nicely (they take them off dead keyboards when people bring them in for service). If you show them what's wrong, they will probably be able to give you the plastic "clip" that goes with it.
Punteggio 4
1 Commento:
If you're not close to an Apple store your can get them on eBay for $2.75 each here: http://cgi.ebay.com/Apple-Ultra-Thin-Alu...
da
I recently had to order some keys myself, here's a place selling them for $2.50 and they ship internationally too!
http://www.ebay.com/itm/281064247677?ssP...
Punteggio 0
I had a defective key on my 2-3 year old keyboard. Fortunately, I live only 3 miles from the nearest Apple store. They took my keyboard and pulled another off the shelf and gave it to me, no charge. My conscience is clear. I saved a keyboard from the landfill.
Punteggio 0
1 Commento:
Went to Covent Garden store. They tried to sell me the £70 replacement magic keyboard. Dissapointed that I didn't bite their hand off, they then told me to try eBay.
da
Apple do now supply replacement key-cap sets as service spares to their authorised repair centres so although purely sales Apple stores may not be a able to, any authorised Apple service provider (AASP) SHOULD be able to provide replacement key caps to any unibody MacBook Pro. I believe the 2009-2012 pre-retina key caps are only supplied by Apple as full US format sets so they can't supply country specific keys like the UK 3 key. The newer clip types on the Retina MacBook Pros are supplied as international sets covering a number of European country formats.
Having said all that, this does not mean they actually will supply them as this is entirely up to them and they may want to charge you a fee for fitting it.
To complicate things further, before the introduction of their own ‘butterfly’ design, Apple sourced their keyboards primarily from two different companies; Darfon and Sunrex, who used different clip designs under the keycap. Apple used keyboards from both manufacturers on the same range of Macs and the keys are not interchangeable, so just because you get a key from the same type of MacBook Pro you have, it does not mean it will fit. Apple supply the service spare recap sets mentioned above, to AASPs in these two manufacturer versions with two different part numbers. They call them type D or S to match the manufacturer name.
If you get no joy from your local AASP, every type of keycap from every model of Mac (including the older models that Apple don't supply service spares for) can be sourced from The Bookyard.
In the interests of full disclosure, I do work for The Bookyard but as this is the most comprehensive Apple keycap store on the internet, I assume referring to it is justified by it's relevance.
Punteggio 0
1 Commento:
Just went to an Apple store today and this did not work. The only thing they offered was to replace the entire keyboard. So I stopped by a computer fixit store and they just gave me an Apple keyboard they were going to recycle, for me to grab the missing key from.
da
Aggiungi la tua risposta
Jonathan Colburn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 163
Tutti i Tempi: 77,742
