Will not switch to impact mode
The drill will not switch to impact when drilling
Questa è una buona domanda?
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
If Steve is, in fact, referring to a Ridgid R86034, it is not switchable, it's just an impact driver. FYI for all
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 446
