Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Why my laptop shuts down on its own?
I have a problem with my macbook A1181.
When the laptop is running, if I press hard the keyboard or the case on the left or right, my computer shuts down immediately.
At the same time, if I press hard the keyboard, the Shutdown window pops up asking me if I want to shutdown the pc and in some cases after some seconds it shuts down on its own.
I can't use my laptop anymore.
Any suggestions?
Thanks! This website is terrific!
Max
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I fixed it!
I opened up my laptop e noticed something loose on the top right part, above the optical drive.
Now it works!!
Thanks everybody!
Max
Punteggio 2
1 Commento:
I suggest you accept your answer then. Congratulations on solving it yourself!
da
double-check if the top case cable connector is well seated in his socket.
Punteggio 1
Open up the case and see if somethings loose. Also try verifying your HDD in disk utility.
Punteggio 0
Aggiungi la tua risposta
Baaald sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,186
