Salta al contenuto principale
The Linksys EA6900 Smart Wi-Fi Dual Band Router is a four port wireless router with three antennas at the back of the device. The device also has two USB (3.0 and 2.0) ports for memory storage.
How can I reset the Wi-Fi network?
I forgot the password to Wi-Fi network I had set up a long time ago, how can I reset the password?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Since you forgot the password to Wi-Fi network, you need to reset the Linksys EA6900 to factory defaults. There are two (2) ways do this:
Hardware Reset
Press and hold the Reset button on the back panel of the Linksys Smart Wi-Fi Router for about 10 seconds then release.
Software Reset
Log in to your Linksys Smart Wi-Fi Account. Under Router Settings, click Troubleshooting > Diagnostics. Click Reset under Factory reset.
Punteggio 0
Risposta Più Utile
Since you forgot the password to your router, you need to reset it to factory defaults:
There are two (2) ways to reset the Linksys EA6900 to factory defaults:
Hardware Reset
Press and hold the Reset button on the back panel for about 10 seconds then release.
Software Reset
Resetting your router means you are willing to lose following settings.
  • Router username and password.
  • Wi-Fi username and password.
  • Firewall settings.
  • Portforwards you have setup.
  • Any other changes you have made.
Punteggio 1
There are two ways by which you can reset the Wifif Network
  • Hardware Reset
  • Software Reset
Punteggio 0
Aggiungi la tua risposta
Rick Hsu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 8,955
