Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1697 Domande Visualizza tutte
PS4 Very soft beep ( or no beeping )
Hi
When i turn on , off , eject disc , or pressing the eject button ( when there is no disc ) i'm no longer hear the beeping sound or sometimes i hear a very soft beep when i talked to PlayStation Support the told me ( it not affect the performance ) when i hit it from above ( light hit ) i can hear beeping for 1 or 2 hours then the sound disappear again . So is there any fix ?
Questa è una buona domanda?
Punteggio 1
1 Commento
You know the old saying? If it ain't broke, then don't fix it. That rule applies in this situation. My PS4 doesn't beep either, but it still works. So I'm just gonna leave it be.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Sounds like the buzzer/speaker may be faulty. They can be replaced...there's just two pins soldered through the board.
Punteggio 2
4 Commenti:
Thank you very much
da
Bruh I’d be happy if it did that because the beeping is very very obnoxious
da
My PS4 slim work like a normal ps4 but I don’t hear no beeps or lights when it’s on and I can only turn it on with my controller
da
I get like 1/4 or half of a beep
da
Is it mandatory to change them if it does a soft beep?
Punteggio 0
1 Commento:
No, it doesn't affect anything so if it doesn't annoy you then don't worry about it.
da
The beep is a very important part of the PS4. its the only thing telling you whats wrong with your PlayStation. You wouldn’t be able to know any errors. If your console turns on. no beep but its trying to tell you something. your PS4 might be in trouble. I’d suggest replacing it but i cant find anywhere that sells them or even knows where the beep comes from.
Punteggio 0
Aggiungi la tua risposta
Koky Gamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 91
Tutti i Tempi: 25,148
