Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Screen becomes very dim, almost black
I replaced this guy's phone screen, it looks all good. two days later, he said when charging the phone will not turn on. But you can feel the vibrating. I re-insert all plug. It works. Two days, it happened again. This time I unplug all wire (LCD, Digitize, batter), try to turn on, the screen is very dim. I can just see the apple logo, which means the phone is turning on. But after that, I can't see anything. I put another screen on. It's the same.
Don't know what happened. Need help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Albert, Screen becomes very dim. Check the attached links,instruction and guides, Good luck
Replaced Screen now working but very Dim any ideas please?
Black screen after lcd replace
https://www.igeeksblog.com/how-to-fix-di...
Punteggio 1
Aggiungi la tua risposta
Albert Zhan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,120
