Salta al contenuto principale
L'Audi A6 è una berlina di lusso prodotta dalla casa tedesca Audi AG, ora nella sua quarta generazione. Tutte le generazioni dell'A6 offrirono o trazione anteriore oppure la trazione integrale basata sul differenziale Torsen, commercializzata da Audi come Quattro.
My car is haunted
2004 Audi A6 Quattro: Turn signals click but sometimes stop and I have to manually click. Rt. signal interior light does not light. Also the sun roof opens all by itself and when it feels like it and closes by itself. Any ideas where to start my search? HELP.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione prescelta
Hi Andy,
I had a Jetta that did many of these things forever. Turned out to be issues with the faulty electrical wiring. Here's a helpful article about electrical problems in vehicles:
https://gobdp.com/blog/diagnosing-electr...
Alternatively if it is a ghost you can try these steps:
http://www.wikihow.com/Get-a-Ghost-out-o...
Punteggio 4
Andy, check and test all signal light bulbs(even if they look OK), check wires/grounds and plugs for damage and corrosion. IF all are OK, change signal flasher, if still not working could be the multi function/light switch faulty.
As far as sunroof problem opening and closing on it's own, forums I have read say it is the sunroofs potentiometer faulty. Check the attached links,instruction and guides, Good luck.
http://www.audiworld.com/forums/a4-b5-pl...
http://www.audizine.com/forum/showthread...
Punteggio 2
All else failing this link will tell you who to call
in the UK it's
0800 2229 911
USA
1-212-897-1964
https://www.youtube.com/watch?v=Fe93CLbH...
Punteggio 2
Aggiungi la tua risposta
Andy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 579
