Salta al contenuto principale
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
495 Domande Visualizza tutte
model k48 keurig lights flashing
My model k48 has been unused for several months, but still in the house and upright. When I plugged it in, all the lights started to flash and would not stop. Customer service was of no help and offered me a discount on a new one. Anyone have a solution other than buying a new one? Thanks.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Try resetting the Keurig by pressing the auto-off and both the cup size buttons simultaneously. All the lights should go dark and then return to normal. Thanks to Amazon user PJP for the suggestion!
Punteggio 5
7 Commenti:
Did the trick...Thanks
da
I did what you said and it fix my keurig machine thank you very much for your solution.
da
Thanks for the tip. Enjoying a fresh brew right now
da
Thank you!!!! It worked!!!
da
What worked, I don't see a solution?
da
Mostra altri 2 commenti
Thank you, it worked!
Punteggio 0
Did not work. Still flashing Ugh
Punteggio 0
1 Commento:
Tried every solution....unplugging to reset,cleaning needle,making sure water tank is sitting ok and pressing simultaneously the large and medium cup sizes.All lights are still flashing.Even tried a new outlet. Keurig is out the door ,I am back to a reliable drip coffee maker
da
Aggiungi la tua risposta
nicklomele sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 220
Tutti i Tempi: 20,636
