Salta al contenuto principale
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Domande Visualizza tutte
When turned off the fans keeps spinning. Is it normal?
The fans are normally very quiet but when i turn off the computer the fans of the thunderbolt display first starts spinning very fast and after 5 seconds keeps spinning not so fast but keeps running until I power on my computer again. Is it normal?
Questa è una buona domanda?
Punteggio 1
2 Commenti
ya it normal.
da
Like Colonel Hogan answered is not normal, and apparently it is a common problem
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi,
have you latest Thunderbolt Firmware installed ? Check Mac Software updates. There was an update adressing fan related issues.
Update (01.10.2016)
So, now i found this about the problem.
Seems to be an apple known problem.
https://discussions.apple.com/message/16...
Punteggio 1
Hi Colonel Hogan,
Thanks in advance for you answer.
Yes, i've already checked the updates. It is the last version of the firmware (26.2)
It is not normal right? For the thunderbolt display's fans starts when turned off.
Punteggio 0
2 Commenti:
Have you attached external devices to the TBD ?
da
No, all the ports in the TBD are unused.
da
I realize I'm incredibly late to the party here, but if you've got your MacBook charging even when it's off, the fans will cool the power adapter.
Punteggio -1
2 Commenti:
Sorry dude, Its a Thunderbolt display not a macbook that is having the problem.
da
yes, that's abundantly clear. in case you're unfamiliar with thunderbolt displays, they have built-in MacBook chargers. when said built-in MacBook charger is plugged into my Mac and charging, it creates heat. the fans inside my Thunderbolt Display turn on to keep the AC/DC conversion circuitry cool, even though the display itself is powered off.
thanks for giving ME a demerit for YOU not knowing what I'm talking about.
da
Aggiungi la tua risposta
Kojiro Nagai sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 225
