Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
Here is a article I found line which may help. Good luck!
Did you make any software or hardware changes on your computer prior to this issue?
Let’s follow these steps & check if it helps.
a) You may boot into ‘safe mode’ which will start Windows 7 with a limited set of files and drivers. Startup programs do not run in safe mode, and only the basic drivers needed to start Windows are installed, follow the steps to boot the computer in safe mode:
i. Restart the computer.
ii. Start tapping F8 key.
iii. You will get advanced boot option window.
iv. Select the option “Safe mode”.
Refer: Start your computer in safe mode
b) Thereafter, unhide the hiberfil.sys file on your computer.
For more information, refer to this link: Show hidden files
c) Open C: drive, locate the hiberfil.sys file & rename it. Thereafter, check if the issue persists.
Rename a file
da Deleted
