Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Bad wifi and reception after screen replacement
Hi,
As the title says. We work in a shop and repair alot of iPhone 6.. This problem has come up from time to time and we have no idea why. Replacing the antennas never resolves it, and it always ends up with us having to buy a new phone.
We've also reset the settings to no avail.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
No one? It can't be just us.
da
I don't know how you have that issue because I can even get good Wi-Fi and Reception after screen replacement.
Are these issues specific to iPhones with bent housing?
da
Aggiungi un commento
1 Risposta
So changing Wifi/Bt IC doesn't resolve the problem?
Did you check vcc-main & 1.8v at wifi ic? is value standard after changing lcd?
Punteggio 0
1 Commento:
Allright, so I need to be able to measure those. Unfortunately I have no idea how to do that. Obviously I'll have to take some courses to take the repairs to the next levels :) Thanks.
da
Aggiungi la tua risposta
Pwny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 252
