Salta al contenuto principale
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
118 Domande Visualizza tutte
How do I fix a loose charging port?
I have a problem that you might be able to help me with. My phone USB port I think that's what it's called well is loose and my phone doesn't charge well it charges very slowly but I have to maneuver around the cord is there anything I can do to fix it
Questa è una buona domanda?
Punteggio 6
2 Commenti
I had this problem too. The solution was to buy a new good quality charger. It's probably not the device but the plug.
da
my dad has a alcatel one touch and we had to hold the charger in the phone and now it will not charge no more what is wrong
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Briggette, sounds like charging port is warn/damaged, you may need a new port. Drop into any small computer/cell phone repair shop and have them take a look,diagnose and estimate repair. I will post a link for you to see how the port is changed if you would like to try and change yourself.
Check the attached link,instruction and guide, Good luck
https://www.youtube.com/watch?v=VQekmZQr...
Punteggio 4
1 Commento:
Can you use any charger port or does it have to be from the same kind of phone
da
Broken port most likely .
Punteggio 0
1 Commento:
Mine broke going in to charge almost like they werwnr seated properly inside the tablet cuz I felt it go further inside which made it impossible to make connection to charge at all without breaking it open fig out why it came loose and I read some place it's a known issue no less good times lol
da
Aggiungi la tua risposta
Briggette Gonzalez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 29,665
