Salta al contenuto principale
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
32 Domande Visualizza tutte
Display replacement / fingerprint sensor
Hey I replaced the display, but the new display didn't come with a new fingerprint sensor so I transferred the old one and it doesn't seem to detect it. Has anyone had success transferring the fingerprint sensor?
Questa è una buona domanda?
Punteggio 3
1 Commento:
The HTC one 10 that i worked on had a costume ROM which the home and fingerprint senor did not work until we had full assess to the Phone.
da
Aggiungi un commento
4 Risposte
Have you found solution after all? I'm getting exact same problem
Punteggio 0
The fingerprint scanner is part of the home button itself. A lot of people had success replacing this part. I have seen a few iphones (5s) which had screen replaced but the fingerprint scanner was still working.
Punteggio 0
1 Commento:
this is an htc 10 not an iphone 5s, they are very different.
da
I have a theory, fingerprint sensor will only work with a genuine display part.
Punteggio 0
1 Commento:
Thats likely the answer, currently using an on screen home button to compensate, no parts suppliers seem to offer a home button or display assembly that includes a home button.
da
It's confirmed, I've got another display part, this time directly from HTC, transferred old fingerprint scanner, all works fine.
Punteggio 0
4 Commenti:
Hey can I ask how you got the replacement display from HTC? Will they sell directly
da
I've got it from supplier who's known for getting parts directly from HTC stock in the UK
da
Could you please link to the shop? I need to replace the screen of my HTC 10 and would like to know it's a genuine display replacement. Otherwise I would need to find out via trial and error if it's genuine - which is quite the effort considering the low repairability of the 10 :/
da
@Ivan Navi - Could you please link to the shop?
da
Aggiungi la tua risposta
Pete sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,892
