Only left high beam works with no low beams
It's a headlight problem no low beams and only the driver side highbeam works so the question is what would cause this the bulbs have been replaced
Questa è una buona domanda?
Steve, Ensure all bulbs are good(test them), check all fuses and relays (I believe there may be separate fuses for each bulb) locations should be in your manual. Other things that may cause issue with lights are bad grounds, corroded damaged wires,plugs, multi function/ headlight switch defective, if equipped faulty FCM (front Control module), BCM faulty.
Check the attached links,instruction and guides on how to trouble shoot and suggested tips on what to try before replacing parts., Good luck.
https://www.2carpros.com/questions/dodge...
Here is a link that explains how to replace a headlight bulb in your caravan. Tap on or click on the blue link. I hope this helps. Good luck!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,290
