Salta al contenuto principale
I need to replace the ignition coils on my Seat Cordoba
I have a problem with my wife's Seat Cordoba (check engine light). Apparently two ignition coils are damaged (they gave "cylinder misfire", according to the diagnose), but I heard the replacement is very simple. Can I do it by myself, easily? What do I need, where do I start?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's a link that should help. Tap or click on the blue link. Good luck!
https://m.youtube.com/watch?v=HFfGL6AWgx...
Punteggio 2
Risposta Più Utile
I had a similar problem with my Ibiza, the model with the 1.4L. I found a good step by step tutorial about changing the ignition coils on Seat Cordoba/Ibiza and managed to replace the coils by myself. The tutorial describes a 4 cylinder engine. Maybe it can also help you. The repair is quite simple. You do not need tools, just new ignition coils and a few minutes. Thanks and good luck!
Punteggio 3
Aggiungi la tua risposta
Rotty's Tutorials sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 664
