Salta al contenuto principale
Il Nintendo 2DS è un dispositivo di gioco portatile sviluppato come versione entry-level del Nintendo 3DS con hardware quasi identico, ma senza la funzione dello schermo superiore 3D.
Nintendo 2ds problems. Help!
So the problem with my 2ds is that if I turn it on it will not show anything and just power off two seconds later. It was working 20 min prior to this and nothing happened to it at that time. Please help! Ok new development the screens flash and you can hear a small pop from the speaker and then it just shuts off.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
This may help: dsi flashs on and then turns off
It's a different model, but being a Nintendo DS, I'm sure the issue is somewhat relatable to yours.
Punteggio 0
2 Commenti:
Ok it may be the same problem but do you know where I can get a guide for my model?
da
It may be the same problem but do you know where I can get a guide to fix it for my model?
da
Hi,
The little pop is telling you that the unit is in short circuit. Possible causes:
- Broken screen (only way to verify is replacing the screens)
- Short circuit fuses (F1 a/o F2) - multimeter and check for continuty
- Disconnected wifi card - Verify if not sitting properly
Good luck and good repair.
JM
Punteggio 0
Game will not download
Punteggio 0
Aggiungi la tua risposta
Aries sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 366
