Salta al contenuto principale
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
Punteggio 2
ive got a similar issue , what model do you have??
cheers
Phil
Punteggio 0
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
Punteggio 0
Aggiungi la tua risposta
derekseven sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 317
