Salta al contenuto principale
Versione migliorata del Nintendo Game Boy Advance, l'Advance SP è stato rilasciato il 23 marzo 2004 in Nord America, con una struttura quadrata ed un design a conchiglia.
163 Domande Visualizza tutte
Why my game boy not charging?
So I had this game boy for along time but the ac adapter broke and after a lot of years a bought a new one but now the console is not charging at all... not even the red light goes on when I put the charger but the console still goes on and since the battery is dead it goes off right next
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
First of all, check the current output of the charger. If that value is equal or above the one on the original, then the battery is dead and you should get a new one.
Punteggio 2
3 Commenti:
Where can I get a new GBA SP battery? Does Nintendo still manufacture them?
da
A place where you will surely find one is ebay. Or Aliexpress. Sorry for the late reply.
da
Just a quick note, all batteries on eBay are probably not up to full capacity, so they won't last as long as a brand new one. Just pointing that out.
da
I would recommend getting a new battery as Ciprian R said above. If that doesn't work than it might be the actual connecter on the GameBoy. Take a quick peek inside it to see if there are any bent pins or any loose wires or such.
Punteggio 0
Aggiungi la tua risposta
arthurpotterkarate sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,010
