Salta al contenuto principale
Nel 2012, Sony annunciò che la società avrebbe rilasciato una nuova versione della sua console PlayStation 3 del 2006. La nuova console fu chiamata PlayStation 3 Super Slim ed è identificata dal numero di modello CECH-4000. La PlayStation 3 Super Slim (CECH400x) è la terza versione della console per videogiochi PS3 prodotta da Sony Computer Entertainment. Fu lanciata sul mercato il 25 Ottobre 2012.
211 Domande Visualizza tutte
Can I swap hard drives between a ps3slim and ps3 super slim?
I have a ps3 slim160gb hard drive that's located in the front of the ps3 and I also have a ps3 super slim 500gb hard drive that is located on the side now is it possible to swap hard drives and use one in the other? (example ps3 super slim 500gb hard drive and put it in the ps3 slim) or is there any possible I can retrieve the data that's on the hard drive if the ps3 super slim isn't functional anymore or if you need parts to make it or is there any other possible way I can expand the 160 hard drive to a 500 or can I connect the hard drive to a pc to retrieve the data off of it?????
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
It is not possible to retrieve the data if your PS3 does not work. You can dump the data with your original PS3 and some tools, but if you swap the drive, you cannot read any data.
You can use the drive after formatting though.
Punteggio 1
Well first of all, yes, but unfortunately you will have to find a way to UPGRADE the system for our PS3 super slim was placed into my Slim PS3 because it was the Slim PS3’s hard drive is burnt out. so you can, but you’ll need a via media internet or something like that to update the system and has to be the update number given (like for example 1.62) or higher.
Punteggio 0
Aggiungi la tua risposta
Lawrence Boone sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,770
