Salta al contenuto principale
Guide per riparare e disassemblare telefoni di ogni marca e compagnia telefonica, inclusi iPhone e Samsung Galaxy. Procurati tutto quello che ti serve per riparare il tuo telefono da solo.
73577 Domande Visualizza tutte
Vacuum chamber and autoclave
I was doing a little research and I'm still unsure what can I use each of these tools for. From what I read, a vacuum chamber is used for removing air bubbles from a freshly laid LOCA and an autoclave is used to remove air bubbles from OCA.
Please confirm this info and add corrections.
Thank you.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Can you replace autoclave by hot gun
da
Aggiungi un commento
1 Risposta
The vacuum chamber(Laminator) is where it presses down on the fresh glass/OCA to evenly seal it. The autoclave pulls any remaining bubbles out. So, yes, you're correct. :)
Source: I refurbish LCD's everyday!
Punteggio 0
3 Commenti:
This item states that it can also be used to remove Loca bubbles http://www.ebay.co.uk/itm/281906259692
By vacuum chamber I meant a pot-like container, not a laminating machine with the gold plates.
da
That's what I meant, my apologies.
da
Aggiungi la tua risposta
Ciprian R sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 469
