Salta al contenuto principale
Does anyone know what screw these hadphones use?
I have some Marley Liberate XLBT Headphones where one of the screws came out of the the side. Not sure how. I was told to that I would need an 1.5mm Allen Wrench but I don't know where to find the screws that are used by that. Any help would be great. Even the name of the screws.
I tried contacting them but they didn't know and sending in warranty information its been over a week and no response...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Search Amazon for liberate Marley replacement screws, it comes with a driver. This happened to me on Wednesday. I don't have a 1.5mm Allen driver so $15CDN all in is probably (my) solution. But also I'm a cheap guy so hobby shop might just get me fixed up for less than that.
Punteggio 1
I used M2 3mm screws and they worked fine.
https://au.rs-online.com/mobile/c/fasten...
Some threadlocker eg Loctite 243 might also help. Take care with it as it may strip paint or damage plastic parts.
Punteggio 1
Try your local hobby shop. They carry a ton of tiny, allen head screws. Drones and RC vehicles use them and they are always wiggling out. I'd bring your headphones in and see what they have that will fit.
Otherwise, pull the screw out of the other side and measure its total length, pitch and head size. Then you can order one from any of the hobby websites.
Punteggio 0
@asura Did you have any luck with this?
Punteggio 0
3 Commenti:
The comment above is what helped. I'm going to have to order it because for some reason these screws continually come undone
da
Number 2 machine screws.
da
Aggiungi la tua risposta
Greg K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 5,264
