How to Fix Error “whea_uncorrectable_error” on Windows 8.1, Windows 10
Quick solution to fix “whea_uncorrectable_error” in Windows 10
Step 1: Download this PC Scan & Repair tool
Step 2: Click “Start Scan” to find Windows issues that could be causing “whea_uncorrectable_error” in Windows 10
Step 3: Click “Start Repair” to fix all issues.
Solution 1 – Disable Overclock in BIOS
The most common fix for whea_uncorrectable_error is disabling overclock from your BIOS. To do that, just follow these steps:
Open Start Menu and go to Settings
Go to Update and Security, and then to Recovery tab
Click on Advanced Startup and your computer will restart
On advanced startup, Go to Troubleshoot, then Advanced Options and then UEFI Firmware Settings
Click Restart
After the computer is restarted, it should open BIOS automatically, so go Advanced tab
Than to Performance, and look for Overclocking
Make sure overclocking is disabled
Save changes to BIOS (by pressing F10 on your keyboard), and start your computer normally
After disabling overclocking, you shouldn’t face this issue anymore, but if it’s still present, check out one of the following solutions.
Solution 2 – Start Windows in Safe Mode and Check for Drivers
Reboot or close the Windows 8.1, Windows 10 PC
When the PC starts press “F8” on the keyboard or another combination would be “Shift + F8”.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti
Did you try a clean install without putting back the recovery?
da bart
yes i did tried clean installation of window but sometime blue screen appear
while installing window
da Sunny
i know the blue screen when installing windows its probably because the speed of optical drive or hard drive I would recommend you to put windows on USB recommended to be USB 3.0 but 2.0 will work this link can let you install windows 10 official https://www.microsoft.com/en-us/software... but there is some issues u will need good internet you will need another computer maybe your friend or something when you download the file it will say upgrade this pc or create installation media for another device you are gone choose create installation media then you will choose what to install on you will choose you USB then it will make everything for you plug into your laptop and run the installation
da amer mohamed
I already tried that but even clean install window has same problem
da Sunny
