Salta al contenuto principale
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
some images are corrupted
can anyone advise.. I take a series of photos. every so often the message on the camera says 'unidentified image' . on the computer these images are completely scrambled, like cut into random pieces and reassembled irregularly. But only on some of them, the others are fine. I'm about to dismantle the whole camera as the lens is stuck and need to know whether and what I should replace while I'm at it. Thanks..
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@cici the occassional image issue is most certainly not related to any hardware issue. Nothing that needs to be repalced. Try a different card and see if you can update your firmware.
Punteggio 1
1 Commento:
Thanks a lot..
da
Aggiungi la tua risposta
Cecilia Leete sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 237
