Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Help! Cant connect to itunes to restore!
After screen replacement my phone says dissabled, connect to itunes. When I connect to itunes my computer says "to allow access, please respond on your iphone" but the only 2 screens I can access are the emergency sail and the screen that says iphone disabled. I used the same home button, so I don't think it has anything to do with that issue. Can anyone help?
Questa è una buona domanda?
Punteggio 0
1 Commento
I've just completed a factory restore but now have to wait on my wife to bring back the sim card. According to what itunes says.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
When you get iPhone is disabled or try again in a bazillion minutes try putting a sim card in and let the cellular data sync up the date and time for you + turn phone off and on after it syncs.
If that does not work then you need to do a software update via iTunes in DFU mode.
And if that still doesn't work then you need to restore the phone as a last resort
Alternatively the client can put the disabled phone plugged into their computer if they have synced it before and reset that disabled message so they can enter in the passcode.
When battery is unplugged date and time is reset.
Date and time is synced automatically if set date and time is set to be updated automatically in settings and is connected to internet via wifi or sim card cellular data.
Plugging the phone into iTunes syncs date and time too but only if the iPhone is unlocked or been synced with that computer before.
Note that the phone has to not be in airplane mode and/or cellular data enabled for some of these options to work.
Punteggio 1
but what if it does’’t work
Punteggio 0
Aggiungi la tua risposta
Jason sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 19,206
