Kenmore washer water continues to fill overflows on all cycles
Kenmore washing machine will not sop filling on all cycles and all water levels.
Questa è una buona domanda?
Mamie,
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
The pressure switch/water level switch faulty or the hose connecting the switch to the drum may be off/clogged/ or have a hole in it, or there could be a fault in the water fill valve solenoid which may be stuck open from debris or just worn out. Check out the following video. for more instruction on how to diagnose wash machine overfilling. Hope this helps. Good luck.
To add to Pfaff excellent answer:
The water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the water inlet valve does not get enough pressure, the valve may not close fully after the power is shut off. As a result, water can leak into the washer and cause it to overflow. Check the water pressure to determine if it is sufficient.
mayer, your input in diagnosing washer overfill, appreciated.
The YouTube videos are great! I've got sufficient pressure because I took out the little screen filter which was almost totally clogged. But it still fills all the time-- likely the inlet valve circuitry. I'll check that tomorrow.
The video told me all I needed to know. The hose was not sealing where it connected to the water level switch. Thanks much!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 26
Tutti i Tempi: 9,056
2 Commenti
My Washer it hits half way threw a cycle any cycle and then starts to drain and then starts spinning but wont spin hard and wont finish cycle help
da Carrie johnson
@carriej, Carrie, You have posted your partial question in the comment window! To have your question addressed RE POST as a question make model # and your complete question, so we at iFixit can try to answer your question effectively.
da L Pfaff
