Salta al contenuto principale
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 Domande Visualizza tutte
iTunes error -1. Maybe Hardware defect?
Hi,
As anyone had seen the error -1 (unknow error)? Any suggestion for solution?
I had read, that is an hardware problem on Nand Flash, maybe right?
The iPad 3 (A1430) wont turn on after an update.
When i disassemble it, i had checked that the Main Board Flex Interconnector is broken.
I had resolder the terminals and buyed an new flex, but i have my doubts that this is the problem. I'm Wainting the Flex Arrive.
Sorry if some English errors :D
Best Regards
Paulo Silva
Questa è una buona domanda?
Punteggio 1
2 Commenti:
-1 is usually the baseband
da
Hi,
I will try to Reflow it and check if it works...
Many Thanks
da
Aggiungi un commento
1 Risposta
was this resolved?? as im having the same issue
Punteggio 0
Aggiungi la tua risposta
Paulo Silva sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 359
