Salta al contenuto principale
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 Domande Visualizza tutte
Why does my car still smoke?
Car suddenly started smoking, checked sparkplugs and had oil in one of them. Had to replace the valve cover, but the car is still smoking from tailpipe. Looks like white smoke. There is nothing abnormal with the oil or radiator. What should I try next? Thanks for a quick reply.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Nile, Could be bad valve seals if oil level is not going down noticeably. Have a compression and compression leak down test done on engine, the results from that will help diagnose compression issues or lack of which could cause smoking issue, internal engine coolant leaks will also be detected/checked with this test. Check the attached link,instruction and guide and diagnosing, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button.
http://www.gregsengine.com/cylinder-leak...
Punteggio 2
2 Commenti:
Thanks so much for the helpful answer. I forgot to mention that the compression was 155 on all 4 cylinders. Does that change your answer?
da
You can also check your PVC/ line to see if it is sucking oil there, compression sounds good and even on all cylinders, but simple compression test is not the same as a compression leak down test, more info. can be had. Check and read the link to see the info. to be had when performing this test. Good Luck.
da
Aggiungi la tua risposta
nile sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 8,614
