Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Mac turns off with low battery
Hi guys. I bought a new battery spare on iFixit and I've install it on my mac. Everything is apparently ok.
But it happened to me that the battery level was around 14% and the mac turned off without any screen message. It did want to turn on until I connected the magsafe. Unplugging the magsafe caused another immediately shutdown.
So i left it plugged for some time and now it is properly working.
Suggestion about which is the problem affecting my new battery? Thanks
Update (09/09/2016)
Guys, thanks for replying me.
Well, I did the SMC reset procedure as reported by Apple (connecting the magsafe, i pressed control-alt-maiusc at the left of the keyboard and power at the same time). I was sure the procedure got successful because the magsafe led turned green and then orange again.
But apparently this not worked in my case.
So i decided to open again my laptop and I performed the procedure reported not for Macbook Pro, but for the MacBook, i.e. I removed the battery and pressed power button for >10s.
Now it properly works! This laptop will never die!!!
Thanks again
Update (09/22/2016)
Hey guys. I've got a new problem now.
After some days, I've got again the message "battery requires assistance".
What's wrong now?
This is the screen which reports the battery information: https://i.imgur.com/3MDbIGb.png
Some suggestion? Is the battery that iFixit sold me not good?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You might want to consider resetting the SMC:
https://support.apple.com/en-us/HT201295
Punteggio 3
What does the system information battery information say? You can run this directly under application/utilities folder. Look under power section. At the least, the battery health condition should be normal.
Other than that, do a SMC reset and charge the battery to 100% and let it drain couple of times and see if this problem goes away.
Punteggio 1
Hello!
I have the same problem... SMC Reset done, but no change.
Battery removed, pressed Power Button, no change.
When it´s about 7-9%, the macbook turns off without warning.
Any more ideas what i can do?
It´s a new battery from ifixit (SMP).
Thank you!
Punteggio 0
9 Commenti:
Hi Stefan, try also to run a calibration procedure. When the mac switches-off at 7/6%, try to plug the magsafe just to turn on the PC, then wait to reach 0% and the completely switch-off.
da
Hi Mario,
i did not come to 0%. When i plug in the power cord the mac starts, but when i plug it off the mac is "alive" only for a few seconds... Did not come lower than 7-9%.
Tried again SMC-Reset, PRAM-Reset, Safe-Start... No Change! :/
da
Any update on this please Stefan? Have the same problem. Bought a replacement battery from iFixit but the battery warning doesn't come on anymore :( the macbook pro retina just turns off at 10% charge. When I plug in the charger it turn itself on
da
Hi Razvan,
i told my problem to iFixit, and got a new battery. This works, the other battery had a failure...
da
I see. How do I know if my battery has a failure also? Is there any way to test it?
da
Mostra altri 4 commenti
Aggiungi la tua risposta
Mario Barbareschi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 5,001
