Salta al contenuto principale
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
What is this flex cable
hi, what is the flex cable that runs behind the top of phone, its under the plastic bracket that holds ear speaker and front camera, there is points on the top logic board that connect to it,
Update (09/06/2016)
that sounds exactly it, ripped it by mistake, thanks for your quick reply, not an easy cable to locate
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Are you talking about that black flex cable that runs at the top of the plastic bracket that can easily be cut because there is adhesive on it to stick onto the screen's metal frame?
I cut that once (on accident of course) and the phone's GPS ended up having no signal. So I just set it to device only mode.
Two golden connection points on the upper daughter-board right? Getting that part is hard.
TL:DR - It's an GPS antenna flex that connects to the daughter-board.
Punteggio 3
2 Commenti:
Where do you get the part. Found out about that bugger the hard way.
da
I don't know, only way I know is getting it from another phone.
Not even worth the trouble replacing it. Might as well use the phone with no GPS.
da
Aggiungi la tua risposta
jimmy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 421
