Salta al contenuto principale
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
SSD replacement on Surface Pro
Hi guys.
Hope someone could give me a bit of advice regarding Surface Pro SSD replacement.
I was given a 1st Gen Surface Pro 256GB tablet with a dead SSD for free. The unit is in excellent condition and boxed, so I was quite keen to repair it. Using the iFixit guide I managed to remove the screen/digitizer without damaging the assembly or the ribbons.
Now my question is this - can I use any make msata SSD to replace the dead one? Are there any makes I should stay away from for reasons such as bios detection issues, booting problems, etc...
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The term "msata" means mini sata, so there should be no issues with any msata drive as it uses the standard sata interface, that said if I were to make a recommendation I would say get either a Samsung SSD or an intel one, preferably of the MLC or v-nand (also know as : 3D-vertical) flash type as they have the best speed to reliability and pretty good capacity as well
Here is a good one... you can change the capacity,
http://www.newegg.com/Product/Product.as...
Punteggio 0
Aggiungi la tua risposta
Joe Bailey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 670
