Salta al contenuto principale
Why does my android phone charger not work?
I have an android plug-in wall charger that I use for my galaxy s7. It doesn't work unless I bend the head of it (where it plugs into the phone) upwards, then it charges fine. I have used other chargers with the phone, so it is not the phone that is the problem. Is there any way to fix this issue?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
The contacts are loose on the male usb port end, it would require simple soldering to fix, but since chargers are so cheap, unless you have good experience soldering I'd just get a new charger to avoid ruining your phone if you repair the charger improperly.
Punteggio 0
Aggiungi la tua risposta
Nina Glasgo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 105
