Salta al contenuto principale
Il Sony Xperia Z3 Compact è stato lanciato nel settembre 2014.
wifi problem after lcd and back cover replacement
hello, i'm Dan, i have a problem with my z3 compact's wifi. I replaced the lcd and the back cover, and the wifi don't work good... The signal at 2,4GHz is so bad and at 0 mb in download, with the 5GHz is a bit better but not enought. I don't know where is the wifi antenna, and if i could touched it or broked it when i moved the motherboard or others.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check connetor on mainboard and plastic main frame. Wi-Fi antena is in a frame. Check screws and spring connector on mainboard (it goes to frame). Maybe you can broke it or distort it.
Punteggio 1
Aggiungi la tua risposta
dan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,016
