Salta al contenuto principale
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
Why the tablet is stuck and unresponsive?
Hi there All, Today I installed windows 10 64-bit on my ASUS T100H, when I was initiating the installation process the screen rotated, and after the installation the tablet is powering on to the desktop screen but is completely unresponsive to touch and keyboard. Please help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I have to assume that the lack of any response here is due to the same confusion I have. The T100HA comes with Windows 10 64 bit pre-installed, so I am not sure what you mean. There is no actual T100H, even though you can google it and find it, and your model # may say T100H-FU007T or similar. It is still from the series Transformer BOOK T100HA series, and I am quoting a rep from ASUS on that. They have the most awful, confusing, redundant, and misleading system for model numbers in the industry.
That said, if you are trying to do a clean install to alleviate the pressure on the low 2GB of RAM, then I would suggest that you have no drivers for your input devices. Try plugging in a regular mouse to the USB port. Then follow this link https://www.asus.com/support/Download/3/...
Much of ASUStek's systems are proprietary and I don't think anything will work on a Transformer without at least having ATKACPI installed (Read: AsusTeK Advanced Configuration and Power utility). I would think the touch would work with just a HID driver but I can not say for sure. Anytime you are doing a clean install you should always gather your drivers in advance. Windows 10 even has a simple system for pre-loading them during the initialization. Hope this helped, just trying to help clear the board.
Punteggio 0
Aggiungi la tua risposta
Aminho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 787
