Salta al contenuto principale
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Can I modify Thunderbolt display to replace mindisplay with a USB-C?
Hi all,
I have a new Macbook but also a 2012 Thunderbolt display. The Macbook only has a USB-C port and I was wondering if anyone has come across people replacing the Thunderbolt display's Mini Display cable with a USB-C one.
Is this even possible?
Any Mini Display-to-USB-C adaptors were very quickly (and suspiciously...) discontinued shortly after they were released in 2015.
Any advice or info would be much appreciated.
Henry
Questa è una buona domanda?
Punteggio 2
2 Commenti
Do be clear here you want to use the Thunderbolt display with your MacBook, correct?
da
At present there is no adapter for the USB-C to Thunderbolt. and i do not believe there is any other way of doing it :(
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Sadly, there is no means to connect a new MacBook which has a USB-C port to a Thunderbolt display presently. Hopefully by the end of next month we might be offered an answer from Apple ;-}
Punteggio 1
2 Commenti:
Just to keep this updated, there is now an adapter available from Apple - https://www.apple.com/uk/shop/product/MM...
da
This is supposed to work, I have not tried it
https://www.nonda.co/products/hub-mini-u...
Punteggio 0
2 Commenti:
Yep! I thought this hub would do it, sorry nope!
It's only DisplayPort compatible! Not Thunderbolt.
Note the compatibility line at the bottom 'Apple Cinema display only with Mini Display Port' no listing of the newer Thunderbolt display. I know I was hoping too ;-{
da
Aggiungi la tua risposta
Henry Kirby sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,019
