Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Replaced Battery and Now bottom half of phone Doesn't Work.
I just replace my battery in my iphone 5c and now the Home Button, Speakers, Charging port and have noticed it does not vibrate anymore either. All cables are connected not sure what i did wrong.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like partially ripped volume button cable and charging port ribbon cable assembly.
Charging port assembly connects to charging port, home button and loudspeaker including bottom microphone and earphone jack.
Kind of boggles me how people break charging flex when replacing battery or screen.
Punteggio 1
You need to take the battery out and check when you removed the old battery off the adesive and where did you put the spugger to force the old battery off and you could have caught the flex cable as the vibrator on a 5c is at the top and that flex go,s to the volume and to power and vibrator silent switch and its common to catch the flex that is under the battery and if you have problems with the bottom of the iphone then you really need to take all the screws out and check that the flex cable under the loud speaker to the charging port, also was this water damage,?good luck
Punteggio 0
2 Commenti:
No wasn't water damaged just battery was dying quickly and the phone is at least two years old, bought it refurbished. Thanks I'll take a look
da
You will need a new battery if it’s dying that fast,?good luck
da
Aggiungi la tua risposta
Nicholas Spina sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 93
