Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Why wont my LCD Screen/Battery I just got delivered work?
So i had a fall at work and landed on my back off a ladder from about 15-20ft and my phone ended up having the LCD screen crack and slowly started to fade black bit by bit till it was un-usable. I have had back luck with phones over the past while and used up my apple care. I also noticed my battery life was starting to fade dramatically since i fell. So i went to IFixIt and ordered the two components i needed (iPhone 6 LCD Screen and Digitizer Full Assembly & iPhone 6 Replacement Battery) I received both parts and noticed right away that in the LCD case there was a tiny metal bracket loose and didn't think much of it (will re-address this later). My brother has all the equipment i needed to do my step by step replacement for both parts and did everything to perfection even transferring my home button to the new screen, as I was super detailed on what had to be done. I then came to the very last step of putting the two exterior screws in either side of the charging port to then notice they were not screwing into anything, I looking inside to notice the metal bracket i noticed was loose in the packaging right at the start was the missing part, it had broken off prior, i only found one metal bracket and the other was just not in or apart of the case? never the less the LCD Screen wouldn't turn on.. i don't know what is going wrong or if the LCD screen is broken as the 2 metal brackets not attached made the screen loose its integrate of coming to me in functional quality.
Any advice on what might be the problem or any solutions?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Did you make sure not to mix up the screws for the metal plate to cover the display connectors? That's if you have it there.
da
Aggiungi un commento
1 Risposta
You need to send the lsd back to were you got it as if the metal is coming away from the screen then thats the bezel, good luck
Punteggio 0
Aggiungi la tua risposta
Shane Dagg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 41
