Salta al contenuto principale
Repair and support for the third generation of the Flip portable speaker by JBL.
70 Domande Visualizza tutte
Why does my JBL Flip 3 not produce sound?
I just bought a JBL Flip 3 2 days ago, i didn't get warranty because i couldn't afford it. i have charged it twice and haven't gotten it wet, or handled it improperly. i woke up this morning and went to play some music through it and there was a rattling sound whenever i played anything from it. so i turned it off and then back on, and not it doesnt produce any sound whatsoever.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
I have this problem too, I think the problem was the cable I used to charge, I used a cable that was not original, try to unload completely, leave the battery to zero, then charge again, remember to use the original cable . If it works, leave your comment here, thanks.
Punteggio 0
3 Commenti:
i will try this did it work for you?
da
Bagaimana hasilnya?
da
Les cuento mi experiencia, el mio funcionaba perfectamente, hasta que la bateria dejo de cargar y solo funcionaba enchufado, lo abri, le quite la bateria que estaba inflada y habia roto la carcaza de tanta presion, eso ayudo a desarmarlo ya que tiene un flex que da toda la vuelta y es imposible sacar. Cuestion que cuando lo enchufaba sin bateria no tenia sonido, la conexion de la bateria es necesaria para que funcione. Volvi a conectar la bateria vieja y sonaba asi que solo queda comprar el epuesto. Espero les sirva
da
there is a bottom on the inside on the motherboard labeled ir5 and when loose doesn’t play music you have a figure out a way to tighten it back on
Punteggio 0
Aggiungi la tua risposta
Cocoa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,307
