Salta al contenuto principale
We need data card, LTE MIFI tear down section
Many of the non huawei data card mifi cards come without MIMO LTE antenna ports causing problem to signal gain !! we can't connect external antenna, so tearing down these model will help to find hidden ports and connect the MIMO antenna
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Inside mobile phones . (back off only) you should see one or two circular connection ports with a pin hole in the center marked R1 and R2 these are the antenna connections used by the service Tech's. Be advised! You can easily mess the internal antenna settings. Which take special tools and machines to set. Proceed cautiously, and good luck
Punteggio 1
Aggiungi la tua risposta
Sub sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 54
