Salta al contenuto principale
Repair guides and support for iRulu tablets.
Locked out forgot password
Hi, I need to reset my password on Irulu 7 in tablet. Please advise. Thank you.
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
8 Risposte
Soluzione Prescelta
On most Android tablets you are able to get into the Recovery mode by Pressing the power button and either volume up or down at the same time. you will want to make sure the tablet is off before holding the buttons down. once you get a menu you will be able to select Wipe User Data.
the volume keys are how you move up and down and the power button is how you select the option.
good luck.
Punteggio 7
1 Commento:
Thank you Mr. Candido Ortiz. I am trying to avoid Wiping User Data if possible. Any way around that?
da
I can't get pass the lock screen after so many tries I have to wait to try the pass word again.
Punteggio 6
6 Commenti:
I. Can_t. get .my. Password. To. Work
da
I. Can!T. get. My. Password. Working. Right
da
this is not helpful at all!!! i tried to reset it several times and it still does the same thing
da
I totally agree with you I tried over 50 times no luck. How about you?
da
Mostra 1 altro commento
My tablet expro X1s WiFi is not working.
And I forget my pattern please help me.
Punteggio 2
Does the Tablet have to be "Hold the Power Button Down" Off OR Just " Click the Power Button" Off?
bold text
Punteggio 1
It did not work for me
Punteggio 0
2 Commenti:
My irulu tablet expro x2 was locked I reset my tab then I forget my old email and I try every option to open it but it can't please tell me how to open: it is also called bypass
da
still locked out those buttons did not work
da
can you access the menu of your device?
Punteggio 0
I did get pass my Lock screen.but not I'm having problem with password Google send me a lot of code but the same things comes up sign in with the user email .doing it over and over.dont know what else to do.
Punteggio 0
Hold power key down ALONG with the volume down key together...must hold both down at the EXACT time!...wait until screen comes back on and release power key ONLY while still holding volume key DOWN until a menu appears on the screen...I have had to do this several times so don't be disappointed!
Punteggio 0
Aggiungi la tua risposta
islanena2008 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 8,013
