Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
iPhone 4 dock connector only works when cable is bent
My dock connector for my iPhone 4 only works when you hold the cable at an angle. Would I need to replace the entire dock connector or could it be some part of the connector that needs to be tightened.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Are you talking about that charging port flex with the microphone and home button connection? Or are you talking about the charging cable you need to plug it into the charger port at a certain angle.
If it's the second you can try cleaning the charger port with an tooth pick or something equivilant. And try plugging it in and see if it works fine.
If not then you need to replace the charging dock assembly.
I test them by just plugging them in and plugging the charger in and testing microphone. Flex of the cable shouldn't cause it to go bad unless it's already damaged physically is already broken inside.
Punteggio 2
Aggiungi la tua risposta
jnaymie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
