Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Vibrate Ringer Button HELP!
I just finished replacing the back cover. And for some reason the vibrate button wont work. it slides up and down loosely but i could hear the clicking when switching up/down. Planning on opening it up agian. I was wondering if there was a special way to put it in or is it just like the volume button where its just the medal piece and and senses when you push down.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
when you open the phone back up have a close look at the inside of the switch-you'll see a little groove that the corresponding "toggle" on the vibrate flex fits into. have a go toggling before putting phone together-can take quite a few frustrating goes.... try putting phone on the side, secure switch with "bluetak" in the down position, flip toggle to down and then secure.
switch has a straight and a curved end which will only fit in space one way.
have fun!
Punteggio 2
Aggiungi la tua risposta
Dustin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,431
