Is there any way to turn the service light off.
My Audi's service light has been on since I bought it a year ago. Short of taking it to the dealer, is there a way to turn it off?
It is ~2000 A4 wagon.
Questa è una buona domanda?
Are you talking about the "Check engine" light or a light that's supposed to tell you it's time for an oil change?
If you mean the CEL: Don't know where you are (geographically) but in the US, stores like Autozone will tend to loan out scan tools. Most of the time, it's free (you might have to give them a 100% refundable deposit or something). You can check codes and reset the check engine light with such a tool.
For a maintenance light: Check your owners manual if you have it. There is most likely a simple "end user" procedure for resetting the light. If you don't have the owner's manual, try googling for "audi a4 service light reset". There are several results but it's not clear to me whether they are only applicable to certain years of the A4.
Hope this helps, and let us know what works for you!
EDIT: Looks like bramley computers beat me to it. This is one of the procedures listed online but one poster claimed it did not work with his/her 1998 A4 which I believe is the same generation as your 2000. Hopefully it works for you.
EDIT2: I found another possibility on wiki.answers.com:
Press and hold Service button, switch on the ignition. When the service message appears on screen - press 0.0 (odometer reset). That should reset your 'service!' message.
That's worth a try if you actually have a "Service" button.
If you do need a computer to reset it, it might be dealer-only or you might be able to do it with VAG-COM if you want to buy that setup or know somebody who has one. IIRC it's some software and a OBD2<->USB cable. It's Windows only I think.
The time for "scheduled service" light
I think you are correct in needing a tool, possibly an Audi specific one. The people a the Quick Lube tried to reset it with their OBD2 computer and had no luck.
Added some notes on another possibility, marked EDIT2 above.
This is how to reset the light:
# Turn off the ignition
If the above procedure does not work, outlined below is an alternative procedure:
You can also get diagnostic readers/reset tools, or cables & software off eBay, you car should have a 16pin OBD2 port.
I had tried the first version, no luck... I'll try the second and report back!
The second method did not clear the "service!" message, but seems like it might clear something. The button on the right of the display does not pull out ruling out the first method.
You need a VAG-COM cable to reset most codes on these cars as well as to do many other procedures including resetting certain convenience items such as chimes, window and lock behavior.
Ross Tech sells them as well as the software. I purchased one of the ebay knock off cables and I am using the free software from the ross tech site.
This cable is good to have if you do any of your own work. Great for checking codes and in many cases you have to have it to complete procedures (throttle body adaptation, transmission fluid checking).
I use the v-checker tool. Got one on ebay. It has a specific reset for oil changes. Otherwise, find a german auto specific shop. They will probably reset it for free.
Reset service light indicator Audi A4. That it is the full procedure how to reset service light indicator Audi A4. If you like to reset any maintenance oil light after an oil change. Or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for Audi cars. Or any error which appears on the display. Write in the search box the car name for which you want to find information, and find how to reset other service reminders when by yourself.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 31
Tutti i Tempi: 28,463
