Why is troy bilt spray oil from air fliter
why is troy blit spray oil from air filter
Questa è una buona domanda?
Punteggio
0
There is a breather pipe into the air filter and because of this, you will always get some oil into the filter. What I have found to be the problem on the ones I worked on was too much oil in the engine. It is only supposed to be filled to the line on the sight glass.
Check the oil level.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 373
