Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Why would there be no display?! blank screen ...
I just replaced my third iphone 6 plus screen using the excellent step-by-tep guuide found on this site. I did a display test prior to securing the "front display cable assembly plate" ( the small one in the top right of the phone) the screen came on, it was beautiful. i then powered off the phone, propped up screen and began to screw in plate. long story short, the display is blank now. The phone will not power up or display a thing!!
I am at a loss. nothing was done between powering down following the display test and the final screw being put in the plate .....
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
hold power and home for 30 seconds, see if it boots back up.
If it doesn't, plug it into your computer to see if the computer sees it. If it does, then look very carefully at the screen to see if the screen is on, just very dim.
Report back with results.
Punteggio 1
Aggiungi la tua risposta
Kelsey Haughee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 65
