Salta al contenuto principale
Repair guides and support for motorcycles manufactured by the German motor group, BMW.
20 Domande Visualizza tutte
Why wont 1985 bmw k100 stay running
have 1985 bmw k100. turn key, hear fuel pump. press starter, bike starts right up, then sputters and dies. then hear fuel pump again, will start right up again, sputter and die. when engine starts, i dont hear fuel pump. I have changed the ECU and the fuel pump relay.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Too many causes to provide an "answer". On the K's the pump is wired off the level sensor.
I'd lift the pump out, disconnect both + & - wires (put hose over ends=no sparks) and directly put wires on the pump, - to ground & hold the + to the battery just as you start the engine.
This will parse a mechanical vs electrical problem.
If it runs ok, it's electrical: get the Clymer manual (M500) to trace power wiring.
If it still sputters & dies, I'd put pressure gauge inline of pump to injector rail. It should be ~38psi.
The regulator may be bad (pinch the hose of rail to regulator to see), but more likely the pump can't keep up.
I've build 3 K bikes from wrecks and worked on many others.
Punteggio 1
Yes—This could be caused by many things. —- Also consider faulty Hall Effect Sensor, which is used as a crankshaft position sensor. Their failure is not uncommon in older K100s.
Punteggio 0
Aggiungi la tua risposta
bryan christensen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 142
Tutti i Tempi: 1,930
