Where can ii get a replacement battery
Battery is dying - where can i get a replacement
15v 5.4w 1310/A
Questa è una buona domanda?
15v 5.4w 1310/A
Try batterupgrade.com, send them an email.
Good luck!
You can go to a battery shop such as Batteries Plus. They can change the battery for you or you can do it yourself. It requires care in disassembly and reassembly but when shavers cost $100.+ dollars, it's worth it.
I had this same issue with mine (Phillips Norelco Multigroom, not a 3100 model but one with a turbo button on it) and when I took it apart (great tutorial on Ifixit.com) I discovered that it is just 2 AAA batteries soldered in. I just purchased a set of them at my local store and soldered them in. Works great again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,502
