Salta al contenuto principale
The Nerf Dart Tag Swarmfire was released by Hasbro in 2011.
7 Domande Visualizza tutte
Is there a Manual firing option?
Can I manually fire the Nerf Dart Tag Swarmfire with the device not turned on?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
The power switch is found on the top of the Nerf gun near the stock end. The only way to use the Nerf gun is to turn the switch into the "on" position, it does not have a manual firing feature.
Punteggio 0
You could if you found a way to put some sort of hand crank on it
Punteggio 0
Aggiungi la tua risposta
sania Ahmed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 202
