I can hear just on one ear
i tried it with some headphones all working but i can hear just on the right ear the other side just dont work=how can i fix it?
Questa è una buona domanda?
on Bose QC25 The right side isn’t working, i did replace the wire, any tip?
Thank you
EASY !!!!
In most cases, it is the speaker that is the problem !!!
Easy to change:
1. 2 screws inside the earcups and the cloth piece (The earcups are "clips" on plce...use your finger all the way around until you hear click....every 2 cm.....)
2. Use a scalpel to open the cover of the speaker (NB!! warm up a bit first...hair dryer works fine!)
3.Unsolder the speaker and solder a new one !!
EVERYTHING OK !!!
Go to Settings - Accessibility - Audio/Visual and check if Balance is right in the middle - I remember once it got messed up by itself for absolutely no reason, but I fixed it this way in seconds
Why should yoy do this....? when it is no sound in one of the speakers...?
whats the Point...?
Try it - you’ll see ;)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 841
